I finally finished moding and i'm amazed at how good it can look
I'm using Seasons of skyrim ENB with ClimatesOfTamriel and RealisticLightingOverhaul
https://www.youtube.com/watch?v=I3UrtJVBcgc
post-5425-0-00655200-1388813090_thumb.jp
post-5425-0-86493400-1388813112_thumb.jp
post-5425-0-03203800-1388813135_thumb.jp
for grass i use "dat grass" and frankly every grass mod out there
CPU: i7 3820 4.0GHz  CPU Cooler: Corsair H80  RAM: 16GB 1600MHz  MotherBoard: ASUS Sabertooth x79  GPU: EVGA 780 ti  PSU: Cougar GX1050 80plus gold  CASE: Antec 1100
Channel : https://www.youtube.com/channel/UCeH6RheyXBWjRGRcF0ZTilA
https://linustechtips.com/topic/97435-finished-moding-skyrim/
Amazing!
I wish I could get into Skyrim, I have wanted to play so many times, but I just get bored.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303240
also
2014 01 01 00002
TESV 2013 12 28 17 10 25 50
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303244
did you use nexus mod manager?
yes
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303251
yes
what all did you use?
I used this mod list. http://www.nexusmods.com/skyrim/mods/30936/?
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303255
Grass is so taxing but it's worth it! I remember playing morrowind and oblivion, heck even unmodded skyrim and the grass would just stop or you would get closer to something and it would appear out of thin air. I want to at least be able to see everything that's in the game all the time, not just when I'm close by
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303263
yo what trees are those and cpu/gpu? fps? :P
i have an i7 3820 with a GTX 780ti
i get about 40-70 fps
the game uses from 2.2-2.7gb of vram
that is insane!
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303265
Yeah i actually used the same list with seasons of skyrim
i liked seasons for some reason
i dont know
with ofcourse a few more
i actually deleted my mod manager folder in between which had the initial mods about 105
and i lost the whole list
so now i have to go to the mod download history in the nexus website to find my old mods nd reinstall them
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303290
i dont know
ya, i had to redo mine like 3 times to get it to work and now that it works my gpu doesnt have enough ram.
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303302
also what tree mod is that? sorry for the questions :P
that skyrim flora overhaul
and "high res wood and stonework" for bark
with skyrim flora overhaul - heavy snow pines
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303335
really? back when i used flora overhaul i'm pretty sure it didn't add trees to certain areas o.0
Mmmm maybe its "glorious environments" then coz i have that installed as well
i honestly dont have a clue
i lost track of my mods
but try "glorious environments"
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303544
What resolution do you run the game at? That's a bit high even with mods.
lol at 1080p
https://linustechtips.com/topic/97435-finished-moding-skyrim/#findComment-1303764
