Hey, was just wondering if you guys could give some feedback on a PCPartPicker list I put together for my future PC. I'm not the most experienced so there may be massive issues or not, but any feedback would be great. I'll be using the PC for mostly 1440p-4K gaming and some video editing as well. I prefer the look of ITX, plus I just adore the Evolv Shift and also I don't have too much room at my place to keep a larger PC so that's why that was decided. Thanks ?
https://au.pcpartpicker.com/user/Subject1849/saved/7tcd6h
Mr Computer Problems 😢
https://linustechtips.com/topic/974253-help-planning-new-build/
The i7-8086k is bassically the same as the i7-8700k, just a tiny bit upgraded.
You can overclock the 8700K to 5gh, or maybe even higher.
This ones just my opinion, but I think the Asus ROG Strix 1080 ti is better, and looks cooler than the gigabyte, but that's not really important.
I also think you should get the 1tb SSD and cut down on the hard drive a bit.
'My mango is to blo up, den akt lik i don no nobudy HAERHAERHA'
If I'm on this forum, I'm prob in school with my mac messing around with @RFK . Otherwise I'm playing on my beefy PC my dad bought me...        2080ti PC GIVEAWAY
UPGRADED FROM THIS SHIT,  TO ----------------------------->THIS<-------------------------------------------------------------------------
/|https://au.pcpartpicker.com/list/qfyvNQ|\    |MY FIRST BUILD|
\|/ SPECS \|/
|-| CPU - Intel Core i9 7980XE |-| COOLER - Corsair H115i PRO |-| MOTHERBOARD - Asus ROG RAMPAGE VI EXTREME |-| RAM - G.Skill Trident Z RGB 32GB (4x8GB) |-| STORAGE - Samsung 970 Pro 1TB +  Seagate Barracuda 2TB 7200RPM Hard Drive |-| GPU - Asus  Geforce RTX 2080ti ROG Strix OC |-| CHASSIS - Thermaltake View 71 Full Tower |-| PSU - Corsair HX1000i 80+ Platinum |-| O.S. - Microsoft Windows 10 Home 64-bit |-|\
ACCESSORIES
MONITOR - Alienware AW3418DW                  It's 34 inches (if you know what I'm talking about...)
MOUSE - Razer DEATH-ADDER ELITE
KEYBOARD - Razer ORNATA CHROMA
HEADSET - Logitech G933 Artemis Spectrum
SPEAKERS - Logitech Z506 5.1 Surround Sound
FREE V BUCKS KIDZ
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775356
This looks like a ridiculously sweet build. Good job on the part picking.
You definitely have deeper pockets than I do, lol!
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775359
I already have the 4TB hard drive from my previous build, but I'll keep the rest in mind. Thanks!
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775361
If the OP is doing video editing, the OP will need to have a lot of hard drive space to store raw footage.
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775362
You're right, but still for gaming you're gonna need a lot of SSD Space
\|/ SPECS \|/
ACCESSORIES
FREE V BUCKS KIDZ
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775368
3 minutes ago, Subject1849 said:
Well that's why I included the Optane 32GB M.2 as a cache for the HDD, it's included in the other section
Ok, sorry I didn't see that. That's a nice build and I hope it goes well!
\|/ SPECS \|/
ACCESSORIES
FREE V BUCKS KIDZ
https://linustechtips.com/topic/974253-help-planning-new-build/#findComment-11775385
