Got Corsair  ll120s and the 3 pack comes with rgb pro controller. But they will need 4 pwm fan headers, and I have a pump controller, how can I get power to all 4 fans? Will I need a splitter? Are there matx mobos with 5 pwm fan headers? I’m using crystal 280x... pls help
https://linustechtips.com/topic/974130-fans/
you would use the controller that comes with the fans.
you would need to purchase splitters or a fan controller.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/974130-fans/#findComment-11774243
According to https://www.legitreviews.com/corsair-ll120-rgb-led-fan-triple-pack-review_198547/2, the 3 pack includes a fan hub. However the Corsair product description suggests otherwise. If the hub is not includes, it is relatively inexpensive, https://www.corsair.com/ca/en/Categories/Products/Accessories-|-Parts/PC-Components/Cooling-And-Corsair-Link/CORSAIR-RGB-Fan-LED-Hub/p/CO-8950020.
https://linustechtips.com/topic/974130-fans/#findComment-11774518
