Cooler Compatibility
Go to solution Solved by Jurrunio,
Yes
Yes
Desktop benching:
https://linustechtips.com/topic/973895-cooler-compatibility/#findComment-11772111
28 minutes ago, Jonshinki said:
do you think its worth to buy it? for an i5 8400?
not a fan of RGB lights myself. I'd just get the cheaper Gammaxx 400.
Desktop benching:
https://linustechtips.com/topic/973895-cooler-compatibility/#findComment-11772654
12 minutes ago, Jonshinki said:
i just saw a liquid cooler which its the same price with gammaxx GT :/ maybe ill just get the liquid cooler id cooling frost flow +120
sounds dodgy
Desktop benching:
https://linustechtips.com/topic/973895-cooler-compatibility/#findComment-11772674
16 minutes ago, Jonshinki said:
if u were to be choose, the id cooling frost flow 120L or the gammax GT?
I'd stick with the air cooler.
Desktop benching:
https://linustechtips.com/topic/973895-cooler-compatibility/#findComment-11772821
