Display port issue
Go to solution Solved by Aviince,
Thanks for the quick replys managed to figure it out in windows device manager display port was disabled for some reason tried this before but since update of drivers it seems to work so all good now thanks.
Does it work with only one graphics card. Try other display interfaces and you may have to reset your drivers if possible.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/97344-display-port-issue/#findComment-1302409
Did you connect the X-Fire connector ? You know, you can never be so sure, but yeah, like the others just said, try it out with only one 7950 and report back.
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/97344-display-port-issue/#findComment-1302522
