I've recently bought an Arc midi R2 and was hearing really loud noise from one of the fans ( got 1 on the back 1 on the top and 2 on the front and the cpu cooler one still stock fan ) and couldn't figure out what was it. Little did I know it was my fan from the hyper 212 evo. I've used a silencer which makes it run as a 5v one and its super duper quiet rig. My question to you guys is: Should I use a push pull config now that I have my fan on my cpu cooler running at 5 v?
CPU Intel I5-3470 4.0Ghz  Mobo  Asrock Z77 ExtremeGPU Asus HD 7870 2GB 1175/1450 Mhz Ram Corsair Vengeance 8 Gb 1600 Mhz HSF Cooler Master Hyper 212 Evo Case Fractal Desing Arc Midi R2 PSU Aerocool Strike-X 600w 80 + bronzer ( to be replaced ) HDD Western Digital Caviar Blue 1 TB SSD Kingston Vseries 60 GB 6GB/s
https://linustechtips.com/topic/97340-evo-212-noise/
Just get a new fan and run it on push or pull
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/97340-evo-212-noise/#findComment-1302357
Just get new fan
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/97340-evo-212-noise/#findComment-1302377
I have it and it is loud as heck, I am planning on getting a completely silent fan soon though, I am quite the silent freak xD Nonetheless it is a great cooler for it's price
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/97340-evo-212-noise/#findComment-1302446
thanks ! Will probably try to snatch me a noctua
https://linustechtips.com/topic/97340-evo-212-noise/#findComment-1302455
