Need Help for PSU
Go to solution Solved by TheSLSAMG,
23 minutes ago, Justian said:
Thanks, man! Other question can I use this case with my motherboard an PSU? and does my motherboard support a GTX1050Ti Or de I need to upgrade my Mobo and RAM and Processor?
Case: https://www.paradigit.nl/cooler-master-masterbox-lite-3-1/20847320/product?channable=e38048.MjA4NDczMjA&gclid=CjwKCAjwxILdBRBqEiwAHL2R82An6BrwncQJnwlsfFNewN1cnMWzkfEgw8xGGtX6nRoclm_bjOiq4xoCcTIQAvD_BwE
The motherboard and power supply will fit fine in the case, as the motherboard appears to be MicroATX.
As for whether the board supports a GTX 1050Ti, it should work fine. Lenovo likes to use whitelists to lock certain hardware from not working, however users online have been using the non-Ti GTX 1050 without issue so it should be the same case for the Ti.
Hello, I'm new here and I want to ask something about my Motherboard an PSU, Can I use this PSU on my Motherboard?
I don't know what kind of Connections I need for this, I know that I'll need 450Watt of Power. Thanks!
Motherboard: https://www.ebay.com/itm/For-Lenovo-ThinkCentre-IS6XM-REV-1-0-Motherboard-M91-DDR3-03T6647-Mainboard-/173242139881
PSU: https://www.corsair.com/us/en/Power/Plug-Type/vs-series-config/p/CP-9020049-NA
https://linustechtips.com/topic/973336-need-help-for-psu/
Can I ask why you're going with a Lenovo mobo?...
There are plenty of cheap options from better brands. It also supports ddr3 so it's quite old, you'll be wanting ddr4 unless you already have ddr3 on hand. Even then you'll struggle to do things like play games and such.
The VS series it not very good, despite being from Corsair.
how about this, give us a budget on I'm sure someone can find you something better.
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766438
Oh, I thought I'll just upgrade my pc but I already have RAM for DDR3 an Intel Core I7 2600 so I thought let me get a new PSU and a new GTX 1050Ti, not just a whole other pc. Cause my budget is not very high :D
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766470
That power supply should work. I also wanted to do somthing like what you are doing but the motherboard I had was fried. Anyway ya that should work also look for the best deal on 1050ti's and make sure they are real 1050 ti s not knock off fakes.
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766532
They should work together, however the VS units aren't particularly good. I'd try to get a grey-label CX unit at least. You can get a CX450M for $50USD on Newegg.
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766538
Like this one?
https://www.alternate.nl/html/product/1337316?channel_code=110&ad_id=277331707865&s2m_product_id=TN4V6C02&utm_source=google&gclid=CjwKCAjwxILdBRBqEiwAHL2R8wIUrw38vBj0lxXVHLM5pasiZ62ttyrV4N4nP-1Iwm9Pu7snA6F8cxoCFxsQAvD_BwE
What is the difference between grey-label and VS?
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766571
5 minutes ago, Justian said:
Yes.
Corsair's VS units are the lowest end units they make. They use an older, group-regulated design that is less reliable than current independently-regulated units. The grey label CX units are better as they use better internal components and they're independently-regulated.
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766607
15 minutes ago, TheSLSAMG said:
Yes.
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766664
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766765
So I don't need to use a UEFI bios? Can i just buy a 1050 and Place it on my PC without any Problem?
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766781
You should be able to just slot in the new card, whether it be a 1050 or 1050 Ti, and it should work just fine.
https://linustechtips.com/topic/973336-need-help-for-psu/#findComment-11766792
