Hey guys if you can help me please. An Update window poped up telling me to Update my Corsair Utility Engine Software to the Newer "ICUE" software, didnt really need it because I only use it to customize the lighting on my Corsair K95 Keyboard, and mainly usse Corsair Link to customize my Commander Pro which I have 5 Ml Rgb fans connected to. Ok, well i installed the ICUE software anyways and all of a sudden My AIO stops Pumping (Ek Predator 360) and 2 out 5 of my ML-120 Fans stop spinning. So I Uninstalled the ICUE software and still not working! There's nothing wrong with them. When i Restart my PC/And When its booting up My AIO Started Pumping and the 2 ML-Fans start spinning again, but when its finished booting and takes me to my Login screen to get into my desktop, it stops working agian. The Aio and the 2 fans only start working When its in the process of restarting, but when it takes me to my windows desktop it stops working? Wth?...Does anyone know whats going on please help thanks...
May Your System be Silent, and your Frames the Most Violent
:ph34r::ph34r::ph34r::ph34r::ph34r::ph34r::ph34r::ph34r::ph34r:
CPU: i7-8086K (5.1Gh/1.3V)  (Delided) Rocket Cool Copper Ihs Cover upgrade W/Liq'metal.
MOBO: Asus Maximus X-Formula Z370
CASE:  Corsair 570X
GPU: Asus Strix/oc1080Ti
PSU: Corsair HX-1000 80+Platinum
RAM: Corsair Vengeance/RGB 32Gb @ 3200mhz (XMP)
SSD: Boot:Samsung 960EVO/M.2 500Gb Storage:Samsung 860EVO/250Gb
COOLING: Ekwb Predator 360 Aio (Modified: Primo-Chill Soft Tube. Ek fittings 10mm/13mm, Xspc EC6 Coolant, EK Supremacy EVO/Nikel-Block)
ISP: SPECTRUM(TWC): 118Mbps/Download 11Mbps/Upload 56ms/Ping
Peripherals: Corsair K95/Platinum Steel-Series RIVAL 600
Monitor: Asus Strix/XG31VQ 1440P/144Hz
10111001011001011100111101100011010010011101001010111100
https://linustechtips.com/topic/973286-aio-pump-not-working-please-help/
Just now, Origami Cactus said:
Can you go into bios and see if they continue working.
Ok, Ill try that
CASE:  Corsair 570X
I checked Bios and everything is workings, I mean when im in the Bios My AIo is working 100% and Fans all lighting up/Spinning at 100%, But AGAIN when I Boot into my windows desktop the AIO Stops Pumping....still the same...God dam ICUE software somehow caused this, everything was working fine till this stupid ICUe software update...
CASE:  Corsair 570X
I couldn't control the pump speed with iCUE when i upgraded, so i uninstalled it (which sucked because now i can't manage my VOID headset) and reinstalled the old Corsair Link. When both are installed, Corsair Link defaulted to iCUE settings, which were non-existent.
terrible terrible deployment.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
yea, Forget ICUE man IDK even know why I upgraded to ICUE this morning...A window poped up telling to update my CUE software and I did it and now my god dam Ek-Predator 360 Aio Pump is not pumping water when im in my desktop! But everything works when 'During' a restart or in Bios..idk what to do...
CASE:  Corsair 570X
roll back to the last working version? I have no idea why your EK pump would interface with iCUE... but it seems suspect that it was working pre-upgrade and no longer does post-upgrade.
System specs:
