COMPONENTS
CPU: AMD - Threadripper 2990WX 3GHz 32-Core Processor
Motherboard: MSI - MEG X399 CREATION EATX TR4 Motherboard
GPU1 - EVGA GeForce RTX 2080 Ti XC GAMING, 11G-P4-2382-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
GPU2 - EVGA GeForce RTX 2080 Ti XC GAMING, 11G-P4-2382-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
Storage: Samsung - 970 Pro 1.0TB M.2-2280 Solid State Drive
Storage: Seagate - BarraCuda Pro 10TB 3.5" 7200RPM Internal Hard Drive x2
Case: Corsair - Obsidian Series 1000D ATX Full Tower Case
Power Supply: Corsair -AX1200i / AX1600i
Case Fan: Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM  120mm Fans x 5
Case Fan: Corsair - LL140 RGB LED 51.5 CFM  140mm Fan
Case Fan: Corsair - LL140 RGB LED (TwoFans With Lighting Node PRO) 51.5 CFM  140mm Fans
LIQUID COOLING PARTS
K-CoolStream CE 420 (Triple)    3831109860380    1
EK-CoolStream XE 480 (Quad)    3831109860434    2
EK-XRES 100 DDC MX 3.2 PWM (incl. pump)    3831109843017
EK-Supremacy sTR4 RGB - Nickel    3830046995803    1
EK-RAM Monarch X4 - Nickel    3830046992345    2
EK-RAM Monarch Module - Black (2pcs)    3831109857069    4
EK-Vector RTX 2080 Ti RGB - Nickel + Plexi    3831109810477    2
EK-Vector RTX Backplate - Nickel    3831109810507    2
EK-FC Terminal X2 S 3-slot - Plexi    3830046994424    1
EK-HD Tube 12/16mm 500mm (2 pcs)    3831109841280
EK-HDC Fitting 16mm G1/4 - Nickel    3831109846070    16
EK-CryoFuel Acid Green Concentrate 100 mL    3831109880173    2
EK-ATX Bridging Plug (24 pin)    3831109867716    1
EK-HD Tube D.I.Y. Kit 10&12mm    3831109841297    1
I need some recommendations for the fans and memory that is both QLV compatible with the motherboard and also my Ram Waterblock.
I'm thinking of going for 18x Corsair LL120/HD120 and also 6x LL140/HD140.
Going for the blings + power this time.
Any suggestions are hugely appreciated.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/972892-need-help-selecting-a-couple-more-components/
15 hours ago, Alistairoh01 said:
May I ask what your budget is?
I've purchased all the items, so currently all i need are 18x 120 fans and 6 140 fans.
15 hours ago, brob said:
Why not stick with Corsair fans?
Should i go with the HD series or the LLs?
Currently rocking LL series on my 8th gen build.
I will also need to get 4 x Corsair RGB Fan Hub + 4 x Commander Pro with it.
Wow, that’s a lot of fans, how much money is your budget for fans?
Around 800-1000 usd ish?
I would get the Corsair led quiet edition fans. I love them. I have one myself. It’s high airflow and very quiet. There are different colors and 120 and 140 mm variants
https://www.amazon.com/dp/B00F6S0XL2/ref=cm_sw_r_cp_api_W5NOBb87KKX30
https://www.amazon.com/dp/B00F6S0XJO/ref=cm_sw_r_cp_api_m8NOBbGJN25K4
theyre also pretty cheap. 120mm 2 pack is 19 bucks usd
Static pressure is quite low on that one.
Thanks for the suggestion but again they have lower SP compared to the LL and HD series.
I guess I will go with HD series since it's the best despite not looking as good as the LL series.
LL series in my 8th gen build :
Also how do you tell how much static pressure a fan has?
Check the specs.
