USB C Hubs help
Go to solution Solved by FastRDust,
41 minutes ago, MikeKats said:
Hey, I just got a new Xiaomi mi air 13.3 laptop. It has usb c (also that is the charging port) 2x usb 3.0 and HDMI out.
I also bought an Ultrawide LG display, which i would like to connect through display port... Would a USB C hub work ?
Would the usb ports on my monitor work for keyboard and mouse that way?
Thank youu
(I hope this is the write forum for this question)
It's should be plug'n'play with a USB-C hub if the xiaomi USB-C port supports Displayport over USB-C.
Which is should because it is mentioned on their own website.
The usb ports on the monitor are not connected if the display is connected through displayport.
But a USB-C hub with a Type A could be connected to your display to use those USB connectors on the monitor.
Thank youu
https://linustechtips.com/topic/972858-usb-c-hubs-help/
Thank youu
Positive Mental Additude!
Just another Tired IT guy...
https://linustechtips.com/topic/972858-usb-c-hubs-help/#findComment-11761703
