it depends. sometimes it's fine, but expect to have to reinstall.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/972714-help-needed/#findComment-11760096
17 minutes ago, JimmyG said:
Hi all, I am changing from Intel to AMD, and I was wondering if I can just change all of my storage to the new system and have it work without problems or if there is something I need to do with the files on the drives.
Thanks!
if it is a OS it is highly recommend and is easier to just reinstall it. however you can go to devices after the upgrade and show disconnected and uninstall those and than install the mobo and cpu drivers.
if any other drive you will be fine
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/972714-help-needed/#findComment-11760117
49 minutes ago, JimmyG said:
You should probably just reinstall windows
https://linustechtips.com/topic/972714-help-needed/#findComment-11760189
