AIO liquid cooler compatibility
Go to solution Solved by Fasauceome,
Just now, Daniel_1104 said:
I’m guess that’s a yes to my question? Sorry i’m still learning about this stuff
It's a yes because your motherboard socket is LGA 1155.
Hi I’m new to the AIO liquid cooler scene and i’m looking to get a h115i v2 for my 3770k and then upgrade to a 9770k when that comes out. As far as I can tell the compatibility for AIO LC works for every CPU gen until gen 2. Is this true and will I be about to use the same AIO on both CPU’s?
https://linustechtips.com/topic/972701-aio-liquid-cooler-compatibility/
it's compatible with intel 115x, which means 1155, 1150, and 1151.
Primary PC:
PSU tier list
How many watts do I need?
Primary PC:
PSU tier list
