Are you trying to print with flex filaments? The stock mk10 extruders can't handle it - you need to 3D Print a new part that covers that gap to stop it kinking and even then it's a real challenge - print at 10mm/s for any chance. The flexion is an expensive but reliable flexible filament extruder upgrade for these printers if you want to do it a 'lot'.
https://linustechtips.com/topic/972679-3d-printer-help/#findComment-11776366
