Help upgrading my PC
3 minutes ago, Josusa09 said:IF i understood u correctly, i could upgrade the pc i have just changing some parts, without having to buy a new one? If that's the case, what would u recommend me to change and for what parts? Thank u very much for everything
CPU: I'd recommend going for an 8th generation Intel chip. Specifically, the i7-8700K, which is currently the best CPU for gaming.
CPU Cooler: Any air cooler works, and would even allow for some overclocking.
Motherboard: Any Z370 motherboard is recommended.
Memory: I'd recommend a 2 x 8, 3200 MHz, DDR4 memory kit.
Storage: If you're reusing those drives, get a 500GB SSD.
Video Card: Your budget allows for a 1080 TI, which even with the new Nvidia GPUs coming out, will still be one of the fastest GPU's out there.
Case: Any case works.
Power Supply: I'd recommend one that's fully-modular, 80+ Silver or better, and at least 550W.
Hope this helps!
