I am using a Fios home network and then connecting my PC and my server via a router. I use the PC's "Mstsc" remote desktop to transfer files to the server. It takes 10 minutes for 800MB. Also try to use sharing and Using a PC to access, The speed is still slow. And while transferring large files, the speed of the entire house will become very slow, even access to Google will take about 3-4 minutes. I still want to make a Steam Cache server. It seems that this speed is slower to download locally than from Steam lol. Should I switch to a new router or buy a switch(Not Nintendo)?
https://linustechtips.com/topic/972371-about-lan-data-transmission/
Sounds like its only operating at 100mb instead of 1Gbps.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
if transferring wirelessly aslong as they are capable yes.  If transferring by cable u will have to have all devices capable of 1Gbps also.
Internet Speed.....
I am using cable, and I am sure that my server and my PC are all capable of 1 Gbps. The point is while transferring large files, the speed of the entire house will become very slow. like the device that using wifi, or even my PC that was transferring files.
if your transferring lets say to or from a system thats only 100mb/s the 1Gbps will drop its speed to the lowest speed.
I would make sure at first all ur pcs have 1Gbps ethernet cards thats the cheapest option rather than a new router.
Internet Speed.....
Hmmm, sounds good to me, I'll try it, Thank you!
No Problem.
Internet Speed.....
