Hi LTT Community,
I am currently wondering about upgrading my system and what you guys think I should upgrade as I would like more performance all around as in gaming my 980 Ti struggles at 3440x1440, however, I would also like better rendering performance, timeline scrubbing, multitasking. I don't want to build a whole new system at once so was wondering whether you think I should upgrade GPU first or platform?
What I do:
- Premiere Pro (up to 5.2K30 and 4K60)
- Gaming at 3440x1440
- Potentially more in the future
Thanks,
Max
Main PC Setup:
- CPU Ryzen 9 3950X, MOBO Asus ROG Crosshair VIII Hero Wi-Fi X570, RAM 32GB Corsair Vengeance RGB Pro 3200MT/s DDR4 (4x8GB), GPU NVIDIA GEFORCE RTX 3090 Founders Edition, STORAGE Samsung 970 Pro (512GB) + (3x) Samsung 870 Evo (2TB), COOLER NZXT Kraken X72 AIO, PSU Corsair RM850i, CASE Fractal Design Define R6 Tempered Glass Blackout
Peripherals:
- MONITORS LG 34GN850 (34" 3440x1440 144Hz GSYNC/FREESYNC) + Acer XR342CK (34" 3440x1440 75Hz) + Asus VG278Q (27" 1920x1080 144Hz GSYNC/FREESYNC), KEYBOARD Corsair K70 RGB TKL, MOUSE Logitech G Pro Wireless & Logitech MX Master 2S, MIC Blue YetiHEADPHONES Sony WH-1000XM4 & Audio Technica ATH-M50x
Home Theatre Setup:
- CPU Ryzen 7 5800X3D, MOBO Asus TUF Gaming B550-PLUS, RAM 16GB Corsair Vengeance LPX DDR4, GPU Intel ARC A770 16GB LESOUND CARD Creative Sound Blaster ZSTORAGE Samsung 980 Pro (500GB) + WD Blue HDD (1TB), COOLER Corsair H100x AIO, PSU Seasonic Core GM-500, CASE Silverstone Black Grandia GD09.
Peripherals:
DISPLAY 55" LG CX OLED (4K 120Hz GSYNC/FREESYNC), KEYBOARD Logitech K400 Plus, MOUSE Logitech G602, SPEAKERS LG 5.1 Surround Sound System
Main Laptop (2021 HP Envy x360 15)
- CPU Ryzen 7 5700URAM 16GB DDR4 (2x8GB 3200MT/s), GPU Vega 8 iGPUDISPLAY 15" IPS Display (1920x1080 60Hz)STORAGE 512GB NVMe SSD
Gaming Laptop (HP Omen 17-CB005NA):
- CPU i7-9750HRAM 16GB DDR4 (2x8GB), GPU NVIDIA GEFORCE RTX 2060DISPLAY 17.3" IPS Display (1920x1080 144Hz)STORAGE Samsung M.2 PCIe NVMe SSD (512GB) + Seagate Barracuda Pro 7200RPM HDD (1TB)
Backup Laptop (Asus FX503VM-EN184T):
- CPU i5-7300HQRAM 16GB 2400MT/s DDR4 (2x8GB), GPU NVIDIA GEFORCE GTX 1060 3GBDISPLAY 15.6" TN Dispay (1920x1080 120Hz)STORAGE SK Hynix M.2 SATA SSD (256GB) + WD Black 7200RPM HDD (1TB)
https://linustechtips.com/topic/972308-upgrade-advice/
4 minutes ago, ViperMaxGamez said:
Hi LTT Community,
What I do:
Thanks,
Max
1) Could you provide some specs aside from you 980 TI?
2) What is your budget?
Answer those, and I can start helping you.
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756590
Specs in signature sorry forgot to say that :) and as for budget there is no set budget as I was just looking for recommendations
Main PC Setup:
Peripherals:
Home Theatre Setup:
Peripherals:
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756653
26 minutes ago, ViperMaxGamez said:
Wait for the 9th gen to upgrade to the new 8 core since premiere makes use of quick sync, or get an X399 system if you want a lot of cores.
I mean you could get a used 1080ti on the cheap soon enough, but overall I don't think it'd be too much faster than a 980ti assuming yours is overclocked near 1500mhz. Doubt premiere cares about a faster GPU, better for gaming still to be sure.
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756675
I was thinking about the 9900K because of quick sync and yeah my 980 Ti is pretty near 1500 MHz will just have to see about turing even with the price :)
Main PC Setup:
Peripherals:
Home Theatre Setup:
Peripherals:
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756682
My bad, didn't notice them.
Yeah, if you're going to stick with this one for a while, you might as well get a 1080 TI. You won't see really notable performance gains from a 980 TI to a 1070 TI or a 1080.
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756683
As for the CPU, I would have suggested an 8700K, but since you expressed interest in the 9900K, go with that; you won't regret it.
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756688
Really sad how broken premiere is though...
https://linustechtips.com/topic/972308-upgrade-advice/#findComment-11756692
