M4N68T-M V2
Phenom IIX4 965
GTX 660
1TB WD
8GB DDR3
just building a low end Media center
Well the thing worked fine, got the windows installed and everything updated, the thing seemed "glitchy" "Laggy" so i did a cmos jumper pin reset, now the thing wont post at all, everything spins up but nothing, not even HD lights blinking. I'm at a loss, I tried disconnecting everything and starting with one piece of hardware at a time, I tried a cmos reset with no GPU. Help?
https://linustechtips.com/topic/972272-help-with-no-post/
So you tried using the onboard VGA as well and no luck?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/972272-help-with-no-post/#findComment-11756212
