This is an update from my other laptop post, my budget is 1400 aud, and i was wondering if i should get the MSI GV62
https://www.newegg.com/global/au/Product/Product.aspx?reviews=all&Item=N82E16834154830
or the ASUS FX503VM-NS52
https://www.newegg.com/global/au/Product/Product.aspx?Item=N82E16834234951
or the Metabox Alpha x N950TP
https://www.metabox.com.au/store/b238/Metabox-Alpha-N950TP-Laptop
requirements
good battery 6 hours min can be lower brightness, no apps open, etc.
1060 3gb or 6gb whatever
thats it lol
recommendations are welcome (please gimme some)
i live in australia so aussie sites only (e.g jb hifi, scorptec, newegg australia)
thanks!
https://linustechtips.com/topic/972193-laptop-help-again/
N950TP is better overall (build quality+cooling), with desktop CPU too (your budget is limited to 4c4t i3 8100). Can stretch to 6 hrs battery life with 62Wh battery (other 2 options can't)
MSI GV62 above only has 3GB VRAM
Any other models with 1060/1060MQ GPU that has similar pricing? What's your budget?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/972193-laptop-help-again/#findComment-11755555
9 minutes ago, GeneXiS_X said:
N950TP is better overall (build quality+cooling), with desktop CPU too. Can stretch to 6 hrs battery life with 62Wh battery (other 2 options can't)
I found like dell but it has crappy reviews, i said around max $1.4K AUD
https://linustechtips.com/topic/972193-laptop-help-again/#findComment-11755572
Which model? Where did you read those reviews?
Desktop specs:
https://linustechtips.com/topic/972193-laptop-help-again/#findComment-11755576
