Display Not Showing
Go to solution Solved by BrinkGG,
3 minutes ago, EggPlayz_ said:
I've got a new 8086K + Strix Z370, my GPU is still on the way so I am using iGPU right now. Every time I connect a monitor with HDMI it shows normally. When I connect with DP the POST screen flashes and no more signal. I tried a DP to HDMI cable and it works when connecting the DP side to the MB and HDMI to the monitor and stuff shows up.  I thought the monitor DP port was broken and I returned it. Another one came and it still doesn't work. I tried two different monitors and three different DP cables now, only HDMI works. Whats the problem? HELP!
Sounds like a dead Displayport connector, but you were able to use a DP to HDMI adapter from the motherboard to the Monitor, so that rules that possibility out...
Try installing the Intel HD graphics drivers with the monitor plugged in via HDMI, then once they're installed, restart and try the Displayport connector.
Only thing I can think of.
https://linustechtips.com/topic/971967-display-not-showing/
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/971967-display-not-showing/#findComment-11753648
Yeah, Installing the drivers solved it. I think it might be the iGPU being unable to keep up with the 2k 144hz refresh rate when connected with DP, and HDMI limits the refresh rate. Thanks!
https://linustechtips.com/topic/971967-display-not-showing/#findComment-11754879
No problem!
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/971967-display-not-showing/#findComment-11756501
