Hello dear all,
So i have my new 8700k combined with an asus z370 prime-A motherboard and an h100i gtx cooler (not v2) .
From UEFI i set the volts to 1.15 disabled xmp and asus multicore enchancement and left everything else on auto and i still cant keep the temperatures down.
below are the temps while idleing (room temp 25c) which jump to high 70s - low 80s while gaming.
i tried to overclock to 4.7 all cores on 1.25 volts but that was just a dream with temps rising to 100 after 20 secs on aida 64.
Anyone had the same problem and solve it ?
I am convinced that i should delid and change the cooler to the H150 pro.
Any other thoughts ?
Ps.My case is a fractal define R6 with the 2 stock fans in front as intake and 1 stock on the back as exhaust.
The rad is on the top exhausting.
https://linustechtips.com/topic/971251-8700k-high-temps-problem/
thanks we don't need a picture of the machine to diagnose it.
More than likely the thermal paste was done incorrectly , or you have the fans on the rad set so low that they don't actually provide any of the water cooling benefits a water cooler can give.
Got similar setup, and I hit 86c in AIDA 64 at 5.0GHz on all cores.  I agree, reapply thermal paste, reseat the pump, check fan speeds, etc.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Simple steps 1st.
Set fans to max speed. (ensure they are infact spinning)
make sure pump is pluged in and running.
if above is all good then.
Remove the cooler, clean old TIM, reaply new TIM. make sure the cooler is seated and secured properly.
If after that it is STILL running hot, 1 of 2 things is happening.
You have a defective cooler. Since you went with a AIO, you added in points of failure whilst gaining almost 0 additonal cooling power over a top end air cooler.
Or ,
Your CPU has a very bad application of TIM between the Die and IHS, meaning no matter what cooler you get ,your temps will be high.
2 options to fix this,
If u still have warrenty, get it replaced (if they agree to),
or
Delid it and apply Liquid Metal TIM for far better performance.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Does the thermal paste age matters ?
I used a sealed 3 year old arctic mx-4
What did you do with the pre-applied thermal paste on the AIO?  I just used what came on mine and it's working very well. Thermal paste is cheap, get new just to be safe.
If you do infact have a shit chip, not much you can do outside of delidding.
OnePlus Ecosystem:
3D Printing:
i had that AIO also on my old cpu so the paste had to be removed
Then my gut says the new paste is either old or misapplied.
I'd put all your settings back to default and see what temps you get after re-applying.  Enable xmp, all that stuff back to normal.  See what stock base temps you have then go from there.
It's hard to believe that just setting all cores to turbo like that will throttle 100c.  Really rare for the chip to be THAT bad.
OnePlus Ecosystem:
3D Printing:
1 hour ago, SolarNova said:
Simple steps 1st.
Or ,
or
Thank you all for the advise guys i realy apretiate it.
what i did was.
1.I reaplied the thermal paste
2.Moved the rad to the front and reinstalled the stock fans instead of the corsair sp quiet edition that i was running.
Now everything seems to work fine.
The system idles at 25c and while stressing on Aida you can see for yourselves. i think it is fine right ?
Any objections are welcome.
I realy apretiate your interest again.
Mby its time to try some overclocks.
Right, good start and yes, good temps again.  Now OC it and see what you get.  5Ghz should be very easy and stable all day long.  I used Gigabyte's guide, for example.
OnePlus Ecosystem:
3D Printing:
OnePlus Ecosystem:
3D Printing:
