2 minutes ago, October22nd said:
What actually is the difference between PCIe and PCI? Sorry if it's a stupid question. :)
PCI is the original standard, it has been slowly dying for the past generations and it's becoming rare on the newest mainstream motherboards.
PCIe came afterwards and it is the newer standard widely adopted for expansion cards nowadays, the newest generations works on the 3.0 revision which is about the double bandwidth the older PCIe 2.0 revision provides.
PCIe provides more bandwidth than PCI although for certain stuff like a 300mbps WiFi card it still suffices but if you have the choice to go with PCIe favour that.
Personal Desktop":
Luna, the temporary Desktop:
12 minutes ago, VegetableStu said:
Just old tech vs current tech. there isn't many PCI interfacing connections on most modern motherboards these days (save for servers (for backwards compatibility with very old hardware) and a few lower end boards)
PCI is also a parallel connection, vs PCI Express's serial connection (a bit like ATA vs SATA)
Thanks you very much lots of useful information. :)
Thank you very much lots of useful information as well. :)
