Hello, i have a problem with my PC, my Gigabyte AX 370 Gaming 5 motherboard has lots lighting, and every like 30 minutes or so, it got turned off really short (below 1s). and then i got really short stuterring on my PC, i dont know why. and dont know if it dagerous.
this is my rig:
R7 2700X, 4.0 GHz on all 8 cores, stock cooling, deepcool z5 thermal paste
Kingston HyperX Fury 2666 2 x 4 GB RAM
Zotac GTX 1070 AMP Edition
Antec EA 550W Gold Pro 80+ Gold
i dont know if it's cable problem, or electricity problem (since i dont have stabilizer yet), false motherboard, false power supply. all component is new except the VGA
please help me
https://linustechtips.com/topic/970905-pc-problem/
I would do two things, one check all connections you can and am sure everything is properly secured.
Second if that does not work you could try rma the psu it sounds like a power issue also make sure your stuff is grounded correctly
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/970905-pc-problem/#findComment-11743824
Second if that does not work you could try rma the psu it sounds like a power issue also make sure your stuff is grounded correctly.
When you say turned off really short do you mean it restarted? If so then check if your CPU is overheating with that cooler.
https://linustechtips.com/topic/970905-pc-problem/#findComment-11743833
sorry late, recently i buy stabilizer and the problem gone. it's not restarted just the led turned off
https://linustechtips.com/topic/970905-pc-problem/#findComment-11758028
