H110 compatible with Cooler Master HAF XB?
Solved by ferdi2431,
Got it! Seems good but you have to fix the case a little bit from the inside. So Push Config goes ans better Pull but dont test it works fine with push. Pull you can install Like that [CASE ---- RADIATOR ---- FANS --->] ( [RADIATOR
---- CASE ---- FANS --->] don´t work!! because of not enugh space!)
You have to fix the front case flap (Cut out pices of plastic) if you want this [FANS ---- CASE ---- RADIATOR --->] Looks rather best!
Here some pics ([FANS ---- CASE ---- RADIATOR --->]):
