Hey everyone, just a quick question; I've been noticing what I can only assume is noise input delay while trying to build in Fortnite. I heard that this may be due to having vsync enabled. I have it enabled because of course I don't have gsync so the screen tearing was atrocious. Will gsync fix this input delay issue I'm having? Or is there somethi g else I can do to fix this issue. I should mention too that the input delay is most noticeable when using the macro keys on the mouse.
https://linustechtips.com/topic/970645-gsync-fixing-input-lag/
If you have an nvidia gpu, yes.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/970645-gsync-fixing-input-lag/#findComment-11740675
enable fast sync instead
https://linustechtips.com/topic/970645-gsync-fixing-input-lag/#findComment-11740723
