My Set Up-
Geforce Gtx 1070 ti
Intel(R) Core(TM) i5-4590 CPU @3.30GHz
64-bit Operating System, x64-based processor
H97 Anniversary Motherboard
  • ASRock Super Alloy
  • Supports 4th Gen & 5th Generation Intel® Core™ Processors (Socket 1150)
  • Digi Power
  • Supports Dual Channel DDR3/DDR3L 1600
  • 1 PCIe 3.0 x16, 5 PCIe 2.0 x1
  • Graphics Output Options: D-Sub, DVI-D, HDMI
  • Realtek Gigabit LAN
  • 5.1 CH HD Audio (Realtek ALC662 Audio Codec), ELNA Audio Caps
  • 6 SATA3, 6 USB 3.1 Gen1 (2 Front, 4 Rear), 6 USB 2.0 (4 Front, 2 Rear)
Supports ASRock Full Spike Protection, ASRock Cloud, APP Shop, A-Tuning, Full HD
Power Supply 750W
16.0 GB RAM
One SSD 480GB, One HDD 750GB
Monotor- ASUS  VP278, 27inch, 1ms, 75Hz
Windows 10
All drivers up to date.
My dilemma is that whenever I try to play something somewhat demanding I get these skips. As if every 3-5seconds my computer will hiccup in a sense like it is dropping frams. Ive tried V-sync and It helped the issue but it still persists. My Computer is very clean with no bugs. When watching system processes nothing seems to be spiking? Someone please help me with the issue. I've spent so much money on this setup and it does not even work properly. If you have more questions please do ask. Thank you.
https://linustechtips.com/topic/970632-someone-please-help-me/
1 minute ago, SomeonePleaseHelp said:
Not Quite. Multiple games have this issue. My Oculus Rift is has the same problem as well.
list the games that you're having issues with so i can understand it better
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740571
Overwatch
PubG
Fortnite
VRchat
Soulworker online
Tera
These are the games ive played and had this issue since I upgraded to the Geforce GTX 1070ti
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740573
Just now, SomeonePleaseHelp said:
Overwatch
PubG
Fortnite
VRchat
Soulworker online
Tera
you get those lags even on Overwatch or Fortnite with Vsync on?
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740577
4 minutes ago, SomeonePleaseHelp said:
Yes, but only with discord on. If discord is off I still have the issue it is just less prevalent
then i have to say it's a CPU usage issue, either you're not running at full clock or you're running too many things in the background and also the 1070 Ti is too powerful for the i5 so the CPU usage will be at 100% when Vsync is off.
it's a bottleneck basically
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740598
It could be a bottleneck but I'd also be interested to see which drive the games are running off? If it's the 750GB HDD, I'd imagine it would have quite a slow RPM. I guess we would need to see CPU usage and maybe drive usage numbers...
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740657
1 hour ago, SomeonePleaseHelp said:
My Set Up-
Geforce Gtx 1070 ti
  • Digi Power
Power Supply 750W
16.0 GB RAM
Windows 10
my hunch,
1) ram <-- most likely the issue, (you probably do not have a matching set) for example, you have 1 8gb stick and 2 4gb stick with different timing
2) CPU <-- overheating
btw, your CPU is severely bottlenecking your processor.
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740681
My Cpu does run up at 3.5ghz usually when playing games, I am using the SSD Drive. And the HDD almost has nothing on it, so in this case the HDD is no the issue.
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740710
15 minutes ago, Srnewbee said:
my hunch,
I will try 2 8GB set and let you know if that was the issue.
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740712
you do not need a new CPU, a switch in ram will solve the issue
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11740771
3 hours ago, SomeonePleaseHelp said:
I do have 2 - 4 gb ram sticks and 1 8gb.. didnt think about that.
Yeah, I don't think you should run 3 sticks of RAM. Generally not advised. I'd remove the 8gb stick or buy another 8gb stick and run two sticks for a total of 16gb. I think you're on the right track though.
https://linustechtips.com/topic/970632-someone-please-help-me/#findComment-11741153
