I just installed a liquid cooler onto my cpu. I have an RGB static fan in the front of the rad that came with the cooler. I also have another fan that came with the case that is just an airflow fan that I uninstalled. I am wondering if it could increase performance to put it on the other side of the road to help pull air out, or would that just be stupid because it is a rad. I have the radiator mounted on the rear spot in my case (no top spot for rad). Thanks
https://linustechtips.com/topic/970580-static-and-airflow-fan/
An additional fan in pull should help cooling a bit. Just make sure that the fans are running at somewhat similar rpm.
https://linustechtips.com/topic/970580-static-and-airflow-fan/#findComment-11739937
