My motherboard allow pcie to wake the computer but not the Lan port. So I had a TP-Link nic but that seemed to stop working with the WOL (I am using TeamViewer). I bought an intel nic (the EXI9301CTBLK) and the green light blinks indicating it is seeing a connection. It will wake up from sleep mode just fine, however it will not wake from a full shutdown.(S5). What am I doing wrong? I am using NO-IP with a domain, I have the ports done correctly, it just refuses to work after it did for at least four months. Can anyone lend me a hand on this?
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/970270-s5-wol-issue/
Same here. I can wake it if suspended but not if on a full shut down and I've looked for everything on the BIOS.
Alredy tried researching on the web but no conclusive results.
Help pls.
https://linustechtips.com/topic/970270-s5-wol-issue/#findComment-11736981
