UPS with PSU
Go to solution Solved by Tibon,
You are wrong, they are completely different device for different purposes.
A PSU is mandatory in any built, an UPS is optional although recommended.
A psu is used to power the whole system, an ups is used as a backup in case of power outage to give enough time for the user to shutdown the system normally to avoid damage to other components or data loss.
If i would roughly describe these two then, a PSU is a AC to DC converter, while UPS is DC to AC.
this is not entirely correct but maybe easier to see the difference.
you'll still need a PSU, they're completely different.
https://linustechtips.com/topic/969736-ups-with-psu/#findComment-11732070
Edited by Tibon
https://linustechtips.com/topic/969736-ups-with-psu/#findComment-11732101
