So everything seems normal as I turn my PC on. About 5 seconds in, The CPU Led flashes once right before shutting my computer down completely. Any idea what the problem might be? AMD FX-8350 FX-SERIES 8-CORE BLACK EDITION PROCESSOR ON ASUS TUF SABERTOOTH 990FX R2.0 AM3+ AMD 990FX + SB950 SATA 6GB/S USB 3.0 ATX AMD MOTHERBOARD WITH UEFI BIOS.
https://linustechtips.com/topic/969583-need-help/
Did the PC Post?
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/969583-need-help/#findComment-11730675
thing is, just yesterday everything was working great. My cpu is brand new as well. today it just decided to start acting up and Ive tried unplugging everything and the only problem is this i cant figure out, everything is going well and 5 secs in it all goes downhill. only led to flash before shutting down is the cpu led.
https://linustechtips.com/topic/969583-need-help/#findComment-11730729
Can u check if your EPS and 24 pin motherboard cable is correctly inserted on the motherboard and the psu?
https://linustechtips.com/topic/969583-need-help/#findComment-11730741
