Hello everyone.
I need help, yesterday my laptop(vaio VPCSB45FL) showed the bluescreen maybe related to video drivers. It does not let me access the system unless uninstall the drivers in safe mode, just like this starts w7 but without the proper driver.
This is the information that I have of the problem:
Firma con problemas:
  Nombre del evento de problema:    BlueScreen
  Versión del sistema operativo:    6.1.7601.2.1.0.768.3
  Id. de configuración regional:    2058
Información adicional del problema:
  BCCode:    116
  BCP1:    FFFFFA8009C97010
  BCP2:    FFFFF88004CA3A2C
  BCP3:    0000000000000000
  BCP4:    0000000000000002
  OS Version:    6_1_7601
  Service Pack:    1_0
  Product:    768_1
If i try to install the driver it will show bluescreen again. It also causes not being able to suspend the pc, I can only turn off or hibernate. I read that this problem comes from the lack of the same driver.
I hope can help me, attached the error capture and another capture took when I tried to start in linux.
Excuse me if my English is not the best. regards.
https://linustechtips.com/topic/969582-help-sony-vaio-bluescreen/
Have you had any luck fixing this?
Have you installed or changed anything recently?
Your model is second gen Intel correct? What is the full spec and general health of the system?
Despite discontinuing their VAIO range a good couple of years ago now the Sony Community forums still enlist staff members to offer support to existing VAIO owners so it may be worth posting there as well.
Desktop: Intel Core i7-6700k, ASUS Z170-PRO, Corsair Dominator Platinum RGB 64GB DDR4 (3200 MHz), ASUS 1070 DUAL OC, Corsair Spec-Alpha, SanDisk Ultra II SSD (960GB), Corsair CX Series CX750M, LG 34UM88C-P, Corsair H100i v2, Corsair K55 RGB, Windows 10 Education
Desktop 2: Intel Core i7-4790k, Lenovo Sharkbay, Kingston HyperX Fury 24GB DDR3 (2133MHz), Gigabyte 1650 OC Low Profile, Lenovo M93 SFF, SanDisk Ultra II SSD (960GB), Silverstone TX700
Laptop: Sony VAIO VPCEH1L8E, Intel Core i7-2720QM, Sony MBX-247 DA0HK1MB6E0 (REV:E), Kingston Hyper X 16GB DDR3L (2133 MHz), Western Digital Blue SSD (500GB), Panasonic E233037 (CPU Fan), Intel Dual Band Wireless-AC 7260, Windows 10 Home
Other Laptop: HP G7010EA, Intel Core 2 Duo T9300, Crucial 5GB (4+1) DDR2 (667MHz), Samsung 960 Evo SATA SSD (500GB), Windows 10 Home
