So i have been receiving a Blue Screen of Death with the error being 'KMODE_EXCEPTION NOT HANDLED'
I read online that a outdated driver may cause the problem. Could someone recommend a free driver updater software that allows you to scan for outdated drivers and update them for free.
Any other ideas on how to resolve the issue other than updating drivers?
Help is always appreciated. Thanks!
https://linustechtips.com/topic/969526-kmode_exception-not-handled/
In my experience, that's what happens when memory is unstable. Not drivers.
Maybe use Driver Booster from IObit?
Desktop benching:
18 hours ago, TheGlenlivet said:
Try Memtest86 and when it passes 8X on all tests then you can say your ram is probably no the issue.
I tried it and it got a 4/4 pass with zero errors. I have also installed driver easy and bought the pro version to update the drivers. And it doesnt work.
Disable fast startup in power settings
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
is this a fresh install of Windows?
Desktop benching:
1 hour ago, TheGlenlivet said:
You did 4x, not 8x on Memtes86.  I had errors that showed up in test 7x on one stick that caused errors for me.  RMA'd the memory kit and that solved my problem.
This may seem like a stupid question but how do i do 8x memtest86
Are you using the windows version or making a bootable USB?
For the windows version got to 1000%(one thousand) percent with no errors.
For the USB, you can change the test settings before you start,  It's one of the options.
