Need help
Go to solution Solved by BrinkGG,
7 minutes ago, Almighty_Joe- said:
He sent me this when i told him to do the test in 1080 preset
-snip-
Perfect. That looks good to me. less then 1% of variance between this and the other 1060 benchmarks I've seen for Furmark.
*Thumbs up*
8 minutes ago, Almighty_Joe- said:
So I m buying this used Zotac GTX 1060 AMP edition Now just to be sure that it's working properly I told the to test the GPU here's the furmark result. Is this normal? Or is it bad?
Run it on the Preset1080 instead of a 21:9. If you run it at 1920x1080 with 0x MSAA, you should end up with a score around this: http://www.ozone3d.net/gpudb/score.php?which=597390
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/969409-need-help/#findComment-11729095
Also, welcome to the forum. :D
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/969409-need-help/#findComment-11729099
But is working fine with that preset? PS i still dont the GPU with me thanky
https://linustechtips.com/topic/969409-need-help/#findComment-11729104
It LOOKS like it's fine to me. I can't tell if that's the performance a 1060 is supposed to get though since I've never seen someone run the 21:9 1080p benchmark for FurMark.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/969409-need-help/#findComment-11729115
He sent me this when i told him to do the test in 1080 preset41244185_712716452396218_809824762501215
https://linustechtips.com/topic/969409-need-help/#findComment-11729433
-snip-
*Thumbs up*
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/969409-need-help/#findComment-11729466
