Hi there im trying to create a multiboot USB with YUMI and the i want one boot to be kali linux and the other windows7 to go
I can create a bootable iso for windows 10 and Kali Linux etc to the USB but when it comes to the Windows 7 ISO I keep getting problems.
I watched the console this time from start to end and realized it never installed successfully even though it said installation was completed. so basically this is the reason why it won't boot and I get the crash when booting to it.
I've tried another iso for windows 7 x64 but they were the same size in GB, I might try x32 windows 7 cause I know it works because I have windows 10 working through YUMI and I used windows to go basically means its set up and done the partitions etc for me.
And my purpose for all this is because my HDD doesn't work in my laptop and I want to try Kali Linux and windows on the one USB at the moment, I've Windows 10 and Kali Linux working fine on the USB at this moment but I want windows 7?
Also I've been checking if the multiboot is working on my main machine and it does on my main PC if I go to the Boot menu I see UEFI : San Disk 58GB I click on it to boot and it flashes black and returns me straight to the bios where the boot selection is then there's a boot called just San Disk 58GB and that's what works but I've to manually do it it doesn't come up in the autoboot selection in my UEFI bios ? if that makes sense ill include pictures if you don't understand what I am talking about when I go to my laptop the drive doesn't show completely but I believe the laptop is different it ain't like UEFI think its EFI has a boot option called EFI Shell ? and when I boot into it its like a console I've no clue what this is .
Good Syslinux Exists...
A Previous MultiBoot Installation was detected... proceeding to add your new selections.
Delete file: F:\multiboot\Installed.txt
Rename: F:\multiboot\nsr2485.tmp->F:\multiboot\Installed.txt
Create folder: F:\multiboot\Windows-7-SP1-Ultimate-(64-Bit)\YUMI
Creating a Virtual Hard Disk for Windows-7-SP1-Ultimate-(64-Bit). Please be patient, this may take time...
Microsoft DiskPart version 10.0.17134.1
Copyright (C) Microsoft Corporation.
On computer: RICKYSPC
  100 percent completed
DiskPart successfully created the virtual disk file.
DiskPart successfully selected the virtual disk file.
DiskPart successfully attached the virtual disk file.
DiskPart succeeded in creating the specified partition.
    0 percent completed    0 percent completed    0 percent completed    0 percent completed    0 percent completed  100 percent completed
DiskPart successfully formatted the volume.
DiskPart marked the current partition as active.
DiskPart successfully assigned the drive letter or mount point.
Leaving DiskPart...
Copy to F:\multiboot\Windows-7-SP1-Ultimate-(64-Bit)\dskvol.txt
C:\Users\RICKY'~1\AppData\Local\Temp\nsw7681.tmp>echo H:  1>F:\multiboot\Windows-7-SP1-Ultimate-(64-Bit)\dskvol.txt
Installing Windows-7-SP1-Ultimate-(64-Bit) to Virtual Hard Disk. Please be patient, this may take time...
Create folder: C:\Users\Ricky's-PC\Downloads\TEMPYUMI
Execute: "C:\Users\RICKY'~1\AppData\Local\Temp\nsw7681.tmp\7zG.exe" e "D:\Downloads\ISOs\Windows 7 SP1 Ultimate (64 Bit)\Windows 7 SP1 Ultimate (64 Bit).iso" -ir!boot.sdi -ir!install.wim -ir!install.esd -o"C:\Users\Ricky's-PC\Downloads\TEMPYUMI" -y
Execute: "cmd" /c C:\Users\RICKY'~1\AppData\Local\Temp\nsw7681.tmp\wimlib\wimlib-imagex apply "C:\Users\Ricky's-PC\Downloads\TEMPYUMI\install.wim" 1 H:\
C:\Users\RICKY'~1\AppData\Local\Temp\nsw7681.tmp>REM THis file was created by Lance @ windows\ot H:\windows /s
Copy failed
Copy failed
The boot configuration data store could not be opened.
The system cannot find the file specified.
Delete file: F:\multiboot\menu\win2go.lst
Rename: F:\multiboot\menu\nsw15B8.tmp->F:\multiboot\menu\win2go.lst
Copy failed
Copy to F:\boot\bcd
Delete file: C:\Users\Ricky's-PC\Downloads\TEMPYUMI\boot.sdi
Delete file: C:\Users\Ricky's-PC\Downloads\TEMPYUMI\install.wim
Remove folder: C:\Users\Ricky's-PC\Downloads\TEMPYUMI\
DiskPart successfully detached the virtual disk file.
Leaving DiskPart...
Copy to F:\multiboot\Windows-7-SP1-Ultimate-(64-Bit)\YUMI\win2go.lst
Windows to Go (Virtual Hard Disk) (Windows-7-SP1-Ultimate-(64-Bit)) and its menu entry were added!
All Finished, Process is Complete!
https://linustechtips.com/topic/968865-usb-multi-boot-problem-yumi/
