Hey guys!
So I've just bought a new HDD to replace my old one, problem is, when I disconnect the old one and connect my new one, it tells me to select a driver with a system to boot.
The weird thing I dont understand here, is that I'm 100% sure that windows is installed on my other SSD drive and not the one im replacing, but when i connect my old HDD drive again, my system is willing to boot into windows.
Is there a way to fix this without needing to reinstall all things again?
https://linustechtips.com/topic/968604-harddisk-help/
your running on a legacy mode, reinstall windows with gpt partition and set the bios to EFI.
https://linustechtips.com/topic/968604-harddisk-help/#findComment-11721039
go to bios when boot (press f9).
look for UEFI bios mode and enabled it.
plug the new drive and see if it boots.
https://linustechtips.com/topic/968604-harddisk-help/#findComment-11721078
