smallest water cooling ever
Solved by Guest,
1 minute ago, Streetguru said:Why would you do a custom loop for mid range hardware?
an R5 2600/i7 8700 is a better choice for the CPU, should be able to get a 1080ti in that budget without water cooling.
What's your monitor resolution/refresh rate?
actually nvm i think i can fit a full size card into the case I want
