i have a dual monitor setup and i have one 144hz monitor it can do any port and a second monitor with dvi vga with a hdmi converter. i tried using  hdmi for my 144hz monitor on my graphics card and it wouldnt go higher then 60hz so my question is why does the new 20 series only support the hdmi and the cut in half hdmi plug when a hdmi doesnt support 144hz also having one hdmi port would be trouble for me because the card only has one hdmi port unless you can use the half hdmi port for 144hz idk what that cable is called so can anyone explain why there is no dvi and just 1 hdmi and 4 half hdmis
https://linustechtips.com/topic/968484-2080-help/
23 minutes ago, peacefulpolarbear said:
The “half HDMI” connectors are DisplayPort. That’s all I could make out of this nonsense.
You did way better than me.
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
https://linustechtips.com/topic/968484-2080-help/#findComment-11720186
