Posted September 3, 2018 So I got a PC speaker system and i also have a headset for gaming, how do i set it up where i can have a single cable for my green audio port, but lead it off for my headset and my speaker? So I can just simply toggle which one i want? right now, my Cloud 1's are using the green port on the back of my mobo, and I want this cable for my speakers to be hidden. Thanks! https://www.amazon.com/HTTX-Headphone-Headset-Splitter-Control/dp/B01HAVVC94/ref=sr_1_1?ie=UTF8&qid=1535957802&sr=8-1&keywords=3.5mm+audio+cable+splitter+with+switch something like this, I might just get a 3.5mm jack extension so i can have the switch on my desk. I heard they did something like this for HDMI, so i was wondering if they did it for audio ports too. AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000 Link to comment https://linustechtips.com/topic/967871-help-needed-for-cable/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 3, 2018 I simple way is one plug into back of motherboard like headphone and have speaker plug into front io audio port. For my motherboard this is on separated audio device. Magical Pineapples
