Just build a new pc and am trying to get it oc'ed but when I am running the Asus ai 3 and the corsair link they are returning 2 different temperatures sometimes as much as 10 degrees apart? any ideas/which one should i trust? the corsair link from the h100i is running hotter than the one from the board( Maximus vi formula).?
https://linustechtips.com/topic/96745-temperature-sensor-confusion/
Your PC specs ??
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
Thermaltake level 10 gt
Asus Maximus VI Formula
Intel 4770k (4.4)
Corsair H100i (replaced fans with sp120 pwm high performance)
G.skill Trident X 2400 8g x2
samsung evo 500 gig x2 (raid 0)
Asus 770gtx 4gb x2 (sli)
Antec hcp 850 platinum
Windows 7 pro 64-bit.
The AI Suite for my system reports temperatures ~11C cooler than the temperatures that RealTemp GT reports.
It is up to you which one you want to trust, but most people will probably recommend RealTemp or some other similar program.  I would recommend that you download that program and go with that.  If you don't want to download a new program, it would probably be best to go with the conservative approach (ie. use the highest temperature to be safe)
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
