so im looking to buy in to the cooler master rgb fans but was wondering how many controllers i can hook up to 1 pc? cant seem to find that info. i no its uses internal usb header and most mb has at least 2 but how many will the software support? i no you can buy an rgb splitter so up to 12 fans /rgb stips.
also in sted of buying there 3 fan /rgb splitter i can use any rgb splitter right?
 another thing is it can use any 5050 rgb strips but can it use addressable rgb strips?
if i do end up buying it i have some led g1/4 stoppers that i was hoping to put a 5mm rgb led in it but i dont no how i would coneted to the contoller. i had an idea of just soding a 4 lead rgb led off of an rgb strip would this work?
all the info i got was they all use adreno to controls the led.
i found this were a guy un solders the rgb led from an mouse and hooks an 5050 rgb strip to it. could i just not add a few rgb leds off of the altho he siad the mouse dosnet have mush power something like 2.5 to 5v.
https://www.youtube.com/watch?v=neLcAoTAdDo
https://linustechtips.com/topic/967132-cooler-master-rgb-controller/
2 minutes ago, mikedrewsmy said:
RGB_Controller__63473.1511880420.386.513
Which controller are u referring to?
top one
Model Number MFY-RCSN-NNUDK-R1
