I am looking to build my first pc. I want to using it for gaming, some game development, 3d modeling, and possibly video editing. I have done some research for this and I have been looking at the following parts. I would like some advice as whether these are the best options.
CPU:
Ryzen 2700x
I think this would be better for my applications than the 8700k because of the extra 2 cores that would help with everything not in the gaming category. It also seems that the stock cooler that comes with the 2700x is enough to cool the cpu well. This may be less important, but AMD says they will support the AM4 socket with x470 until 2020 at least, whereas there is no guarantee with intel.
GPU:
¯\_()_/¯
I was originally planning on getting the 1070-ti, however I am not sure what to do with RTX. I like the look of ray-tracing, but few of the games I play will probably support it for a few years at least. I have been considering getting a better 10 series card or getting a cheaper one to sell and buy an RTX card in the future, or should I just buy and RTX 2070. I have no idea.
Motherboard:
Not to sure here, but the AORUS x470 ultra gaming fits my all requirements, except for wifi. Should I get the Aorus x470 wifi 5, or a $15 wifi card, or a completely different motherboard?
Memory:
16 gigabytes of 2133 DDR4 8x2. Don’t think speed really matters for the things I am doing.
Storage:
Samsung 970 evo 250 gigabytes. I know that the intel 660p series is cheeper, but it is quite a bit slower it seems.
Also an inexpensive HDD for around $50. Any suggestions?
Case:
Not so sure about what case to get. I like the look of the NZXT H500i, but I am not sure whether it is the best option.
Power Supply:
Absolutely no idea about this. PCPartPicker says that this build will need a 400 watts, but I don’t know how reliable this is and I also don’t know how to look for a PSU.
OS:
I think windows 64 bit home should work
Monitor:
I currently have a Dell Ultrasharp U2515H Monitor. 2560x1440 @ 60hz oc up to 80hz with a 6ms delay. I have used it for the past year or so and like it very much. I think that for my uses the extra resolution is better than the higher frame rate you would get at 1080p.
Mouse and Keyboard:
For this build I would like to get a nice mouse and keyboard, however I don’t want to spend too much on them. Any suggestions?
Some of the games I am playing include:
Paradox Initiative games
Civ VI
KSP
Software I am planning on using:
Unity3D
Autodesk Apps
Adobe Creative Cloud
Any suggestions would be welcomed. Thanks in advance.
https://linustechtips.com/topic/967023-pc-building-advice/
Hi there, well currently it seems you would need a decent psu, especially considering how you have an rtx 2070 as an option! There are currently some sales going on with 1070's and 1080's. If you're saying a 1070ti will hold you for a few years of gameplay, I would not get an RTX 2070. Maybe consider a 1080 or 1080ti for 100-200 more than the 1070? The psu you should consider, personally, I would say getting at least a 550-650 psu Gold, if it's in your budget then heck get a platinum.
PC cases are always a little difficult to decide on because it's a tug and war between design and function. I love Fractal Design's meshify series. It's a mid ATX tower with great airflow.
As for the mobo, no clue. I would not say I'm advanced enough to give someone a 100% correct answer.
Might I ask what your budget is? You're considering things like the RTX2070 (expensive as heck) but want a hard drive for under 50? I would grab a 2tb hard drive as they're normally not much more than a 1tb.
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706629
What's your budget like?
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706655
CPU & Motherboard (GET IT ASAP):
https://www.newegg.com/Special/ShellShocker.aspx?cm_sp=Homepage_SS-_-P5_3860219-_-08312018&Index=5
Rest of the build:
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Amazon)
Storage: Samsung - 970 Evo 250GB M.2-2280 Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.39 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($454.98 @ Newegg)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.77 @ Amazon)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($123.89 @ OutletPC)
Total: $1062.00
Generated by PCPartPicker 2018-08-31 16:23 EDT-0400
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706681
The reason I added the 1080 there is because of RTX announcement 1080 prices are constantly dropping. I would look out for deals every day and pick up a 1080 for around the same price as 1070.
Right now, 1070 is around $390
1080 that I linked is $454
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706689
Also, even though you might not need the higher RAM frequency, it's actually better to have around 3000Mhz with Ryzen processors because of how they are made.
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706693
Well first off I'm am partial to AMD but your thought process seems sound, by the sound of it your budget is open I would only add that first gen Ryzen is a freaking absolute deal right now so I would not count that out, for example the 1800x is currently $200 US at Microcenter so if you went that route you could put more of your budget into your GPU which in my opinion is more bang than the 2700x and a lesser card and you could pimp that out with a killer NVME ssd for raw speed again the motherboards are also coming down for first gen so it's something to consider
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11706701
Thank you for answering quickly. I am going to order the parts Krosis listed, though I have a few questions. The newegg deal has ended before I ordered it, but my local microcenter is selling "AMD Ryzen 7 2700X with Wraith Prism Cooler, ASUS TUF X470-Plus Gaming CPU/Motherboard Bundle" for $389 and "AMD Ryzen 7 2700X with Wraith Prism Cooler, ASUS ROG Strix X470-F Gaming CPU/Motherboard Bundle" for $419. Should I buy either of these or should I order them separately online? Also the Fractal Design case does not comes with two fans. Should I order two more to fill the empty fan slots?
https://linustechtips.com/topic/967023-pc-building-advice/#findComment-11709623
