24pin
Go to solution Solved by FastRDust,
5 minutes ago, thegreengamers said:
Along with pushing down the clip, put one hand on the port and wiggle the connector back and forth to loosen it. They are surprisingly difficult to pull out for some reason...
or carefully place a flathead screw driver underneath the locking clip on the cable side and twist slightly to loosen it's grip.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/966513-24pin/#findComment-11701700
Positive Mental Additude!
Just another Tired IT guy...
https://linustechtips.com/topic/966513-24pin/#findComment-11701719
