Can I ask what is the Spdif_o on my motherboard? It looks an Add_Header. Please let me know what it is!
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
https://linustechtips.com/topic/966372-spdif_o/
It's a header for a digital audio port -- optical or digital coax.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/966372-spdif_o/#findComment-11700302
Just now, 79wjd said:
It's a header for an optical audio port.
Can it be used as a header for something else or is it strictly for that?
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/966372-spdif_o/#findComment-11700303
As far as I know it can only be used for digital audio.
Do you need another header for something?
PSU Tier List | CoC
https://linustechtips.com/topic/966372-spdif_o/#findComment-11700316
Yeah, an Add_Header for RGB lighting. This port is two on one side the one of the other just like that port so I tho it might be it. My mobo dosent have an header for that so I guess il have to get one that does. Thanks for your help!
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/966372-spdif_o/#findComment-11700400
S/PDIF = Sony/Phillips Digital Interface.  The "0" is just the port number/address (In laymans terms). Id-Est SPDIF_0, SPDIF_1 et-al
This Wikipedia page about S/PDIF may prove useful..... or not, as the case may be.
Instructions ? WHAT?!?!?! A man don't need instructions!       Oh............wait a minute...........................What's this bit for?  aaaaaagh!!
Vita imitatur artem, imitantur vitae
Lenovo M73 10AXS38G00 i7 4785T 2.20GHz, 16GB Ram, WD Black2 1.2TB Dual Drive, W7 64bit Ultimate, Lightscribe mulit-write Optical.
Lenovo M73 10AXS06G02 G3220T 2.6Ghz, 6GB RAM, 320GB HDD, W7U, Stock DVD Optical
Lenovo T420 42369N8, i5 2520M 2.5/3.2GHz, 16GB Ram, 256GB SSD (iOS 10.13.6 High Sierra), 750GB WD HDD (W7 Ultimate) Dual Boot, Lightscribe mulit-write Optical.
Lenovo L412 4403CT0, i5 520M, 2.4Ghz, 6GB RAM, 320GB HDD Win7 Ultimate Stock DVD Optical.
Custom (re)Build Tower (WIP). Asus Prime B350 Plus Mobo, GTX 960 GPU, Custom MOD Watercooling, Gamemax Falcon Case (two windowed side panels), RGB fans, dual rad CPU loop with 240 & 280 Rads, 120 GPU Rad. RGB Fittings, RGB & BL case lighting. Custom acrylic internal shields/shrouds. Remainder TBD.
https://linustechtips.com/topic/966372-spdif_o/#findComment-11700417
  • 2 years later...
This old man explains it very simple in the video in the link, plus there's multimedia add-ons like 5.25" Desktop Media Dashboard Front Panel that will fit in the drive bays, if your so inclined to use it. I am just posting on this old discussion just because someone might find it useful in the future if they plan on building computer repair rig and want to get more use of their motherboard,when anyone buys a header converter/adapters for a device make, sure everything is compatible.
Research prevents unwanted damage, you don't want.
(https://www.youtube.com/watch?v=OnTCjrLHI3k)
https://linustechtips.com/topic/966372-spdif_o/#findComment-14807839
