Hello,
Asus strix 1060
Skylake 6700k
Asus 170a pc mate
Aerocool templanius imperator 750w
16g hyperx fury ddr4
And kingston's 240g ssd as an boot drive
So here's the deal. Yesterday in the middle of an gaming session my pc died, like some has pulled the plug of the wall. After this, system tried to boot itself again several times allways dying after 3 seconds or so and then no life at all, complitely dead.
So obviously i thought, "ok the power supply must be dead". Off i went and bought an new one. After replacing it, i plugged it back and it booted. Windows started up normaly and after a minute or so it died again. after that it didnt react to anything, complitely dead. Next i tried some old 600w power supply and same result. Only this time it stayed on for like 5minutes.
For me this problem is really wierd. After it crashes it doesent react to anything i have tried of disconnecting components and see if i can get it to boot, but no luck so far. It seems that only way to get it starting is disconnect the power supply and after an few hours pluging it back on.
What do you guys think whats causing this? First thing that came to my mind is motherboard. But without an test bench the only way to troubleshoot this type of problem is mindlessly buying new hardware untill the problem disappeares.
Does anyone had simillar problems or ideas what could be causing this type of failure?
https://linustechtips.com/topic/965719-hardware-issues/
Sounds like a borked motherboard. Take it to a Micro Center or Fry's and they can test it for you
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/965719-hardware-issues/#findComment-11694228
Your motherboard VRM is probably fried. Hopefully it didn't damage your CPU when it blew.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/965719-hardware-issues/#findComment-11694245
