Anyone know any cheap(ish) cable toning and testing tools? One of the other locations at my work was able to purchase this (   https://www.amazon.com/Fluke-Networks-CIQ-KIT-CableIQ-Generator/dp/B007SSX5PE?ref=ast_p_ei   ) and I got to use it a bit which was great, but im not at that location with that type of budget (nor do I need nearly half of those features). Im looking for toning and cable testing capabilities. Anyone know anything for $40-80ish that is good? I prefer Amazon but I can do anything. Thanks
Breaking things 1 day at a time
https://linustechtips.com/topic/965359-need-cable-testtoning-tool/
What's your definition of cable testing?
In that price range you pretty much just get a wire map, which isn't as useful as say the fluke you listed that can do things like SNR analysis or similar.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
