I thought it would have been a good idea to enter the BIOS and turn my CPU and PCIE frequency up to 230Mhz and 130Mhz. I then left the BIOS, saving my changes and my computer restarts. I then wait for a display on my monitor to pop up and nothing happened.
     I tried restarting multiple times, switching from HDMI to VGA, completely unplugging my computer and I am still getting nothing.
     I have an AMD 4300 and a GTX 1050ti, if that is relevant information.
https://linustechtips.com/topic/965277-no-display-connection/
Clear CMOS (Shorting the CMOS jumper or removing the CMOS battery).
Try that first.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/965277-no-display-connection/#findComment-11690036
7 minutes ago, IvanGulag said:
I’m looking at my motherboard now and I can’t find where the cmos battery is.
What motherboard are u using?
https://linustechtips.com/topic/965277-no-display-connection/#findComment-11690112
