Back about 2 months ago my computer just stopped dead in its tracks while I was playing overwatch. I thought it was the PSU because it was making an odd clicking noise, so I RMAed it. It wasn't that, so I RMAed the mobo. Now the motherboard is here, it is still having this issue.
What happens:
While everything is in there I hit power and it makes four clicks from the PSU and then stutters the fans and stops. remove the graphics card and it does the same thing with a slightly longer fan stutter. EVERYTHING besides the back case fan and the CPU cooler out it stays on for about 13-20 seconds, and then resets. If I unplug all the HDDs and GPU it starts strobing and shutting on and off and on and off really fast. I did all the math and the absolute max my pc takes is 350 watts, and I have a 650 watt PSU.
I really have no idea what to do next. We have taken out the CMOS battery, removed everything. Send the PSU and motherboard back. I even got new RAM just in case that was the issue, it wasnt. Im at a loss. I have no idea what to do next. It might be the CPU?? That's my only idea, it wont even post :/.
Any and all help would be super appreciated. I can send videos and pictures as needed, but the file limit is 20 for this post. Thank you in advance.
H370M D3H
i5-8400
GTX 970
650 watt g3 PSU
20180825_111919.mp4
https://linustechtips.com/topic/964669-i-need-help-really-badly/
Full specs?
Just to make sure, you have motherboard standoffs installed, correct?
One thing you could try, turn the PSU off, then hold the power button for like 30 seconds. Then go turn the PSU on again and try (this is to drain the caps in case something weird is happening with the PSU).
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
@DocSwag Yes my standoffs are installed but a little loose. Only a small amount of shake. When this happened they weren't lose, but after install and uninstall like 8 times its slowly happened. I tried your idea, nothing :(
Full Specs:
H370M D3H
i5-8400
EVGA GTX 970 FTW edition
16gbs DDR4 Corsair Vengeance RAM
Noctua NH-U12S
5x Thermaltake Ring12 fans
EVGA 650 watt g3 80 plus gold
250gb m.2 SATA SSD WD-B (boot drive)
2tb,1tb,750gb,250gb HDDs
Full Specs:
H370M D3H
i5-8400
Noctua NH-U12S
You could try unplugging everything you don't need (unplug all storage drives, fans, and GPU; maybe get rid of all but one stick of RAM too) and see if it boots then. If that still doesn't work, you could remove the mobo from the case and see if it works outside the case.
I feel like it's possible something is shorting out due to whatever reason. As a side note, for the cables you're using with the PSU, are they the cables that came with the G3?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
