Seems fine to be, though I'm astonished by how rubbish the memory timings are.
Desktop benching:
https://linustechtips.com/topic/964122-am-i-doing-right/#findComment-11680599
33 minutes ago, Gamerfiend_ said:
Dual channel at 1329.8Mhz equates to roughly 2666Mhz, seems to be fine to me
That's not what dual channel does. Dual channel only widens the memory bus from 64-bit to 128-bit. The effective speed doubling of the original 1333 bus speed is because of DDR, Double Data Rate. Contrary to single data rate memory, DDR memory can perform two actions per clock cycle, effectively doubling the performance.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/964122-am-i-doing-right/#findComment-11680618
but my settings is fine?
https://linustechtips.com/topic/964122-am-i-doing-right/#findComment-11680622
Yep. I'd personally try to set the command rate to 1T. Should improve latency.
https://linustechtips.com/topic/964122-am-i-doing-right/#findComment-11680632
2 minutes ago, Arcana said:
on bios?
Yes.
https://linustechtips.com/topic/964122-am-i-doing-right/#findComment-11680657
