so my friend has a small issue, every time he restarts the pc it ask for a bootable hard drive, we try swapping sata ports, configuring the BIOS and is AHCI mode, formating the secondary HDD, we tried disconnecting the secondary HDD and the DVD but nothing. So i know i´m missing something here but what? what i haven´t done,  what is missconfigured.
thank you guys in advance
with me whoever, ahead who can
https://linustechtips.com/topic/96364-booting-problem-from-primary-ssd/
Is the ssd selected as the primary boot device in the bios?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
This is a bios issue.
Make sure there are no sd cards, flash drives or external hard drives plugged in at boot. I had an old Acer laptop that used to do this as well as an old HP workstation.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
Repair the boot manager then set the OS partition as active.
http://www.gfi.com/blog/top-5-free-rescue-discs-for-your-sys-admin-toolkit/
If the OP has the windows install media, it can be done easily like this:
http://www.redmondpie.com/how-to-fix-windows-8-mbr-master-boot-record/
