So, my PC is using the Aerocool p7c1 case with the plastic side window on the left, so its a pretty big mid-tower. My desk is currently facing flat against a wall and has 2 monitors on it with no room for the computer on the desk, however i want to see the internals of my PC as its lit up with led's etc and is gonna get a few upgrades soon as well as have it off the floor because the carpet does cause some issues with picking up a lot of dust and fluff and i don't want to clean my PC that often. does anyone have any solutions to this problem, such as PC stands or something that would look decent as well, maybe to match my wooden desk?
Also whats the best way to clean out your PC of dust without damaging it because i'm very paranoid every-time i open my computer case
Thanks,
Jensen
https://linustechtips.com/topic/962911-help-pc-window-case-stands-or-placement/
2 minutes ago, Gamerfiend_ said:
Id look at a similar height side table to sit next to the main desk, that's what I did, in regards to cleaning I use compressed air, you can buy it canned & it blasts the dust off with no contact, reducing scratches on plastic etc..
Alright, ill have a look if i can get any but i'm limited for room so i may end up completely replacing my desk :( And thank you for the cleaning suggestion it confirmed what i was going to do. :)
  • 1 month later...
You can get a stand that will match the décor of your room, or a wooden one to match your wooden desk. There are plenty that still allow the insides of your PC to be viewed. And I wouldn’t recommend blowing dust off with a duster of something like that. Wiping the dust away in the best way to clean PC components.
