Hi,
just started building a new computer. I'm having a issue with the CPU.
CPU: i5-8400
Motherboard: MSI B250I
The computer will turn on, but after 1 sec it will shut off and tell following error on motherboard:
"CPU - Indicates CPU is not detected or fail."
The whole build is new, but the GPU, and that's unplugged.
I have tried following things:
1: reinstalling CPU and cooler
2: reputting thermal paste on
3: making sure no pins are bent (CPU was installed correctly)
video-1534845767.mp4
Thank you! :)
https://linustechtips.com/topic/962886-cpu-not-detectedfail/
38 minutes ago, andi365 said:
Hi,
CPU: i5-8400
Thank you! :)
i was pretty confused for a second when i saw you're using a B250 motherboard, i was like "why is he using an AMD motherboard for Intel CPU?".....then i remembered B250 is Intel... f*** you AMD for doing this
anyway............ you're using the wrong motherboard for the CPU, it should be a B360 motherboard, B250 only supports 6th and 7th Gen CPU's, you're using an 8th Gen.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/962886-cpu-not-detectedfail/#findComment-11668502
